-ALIGNMENTVIEW command
Creates a vertical alignment view for the selected horizontal alignment via Command line.
Metoda
Select a horizontal alignment or a 3D alignment, then pick the origin in the drawing to insert the vertical alignment view.
Uwaga: If a horizontal or 3D alignment is already selected in the drawing, you are prompted to select the insertion point.
