-APPLYAUTOMAPPING command
Updates existing civil points via Command line to match the current Auto Mapping definitions.
Opis
Updates existing civil points and the linework between them via Command line to reflect the active Auto Mapping definitions, without deleting and reimporting the points.
Metoda
Select points to update or press Enter to select all points in the drawing. Then, press Enter to update the point selection set according to the active Auto Mapping definitions.
You can also run the command on an active point selection set.
Uwaga: The auto mapping codes are generated in the Edit Auto Mapping Set dialog box and Edit Auto Mapping Commands Codes Set dialog box.
