AMPOWERDIM_HOR command
Creates linear horizontal dimensions.
Icon:
The command is a shortcut to the Linear Horizontal option of the PDIM command.
Method
Select two points and the location of the dimension line.
The Edit Dimensioning dialog box opens to define the parameters of the dimension.
Note: For more information about the dialog box, see the related article Edit Dimensioning dialog box.
After the aligned linear dimension is created, you can define new dimensions by choosing PDIM command options.
