BOX command
Creates a 3D solid in the shape of a box.
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the BOX command launches the AI_BOX command.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Icon:
Create a 3D solid in the shape of a rectangular or square box. Choose from a combination of options including corner, center, length, width, height, and cube.
  1. Center of box
  2. Corner of box
  3. Opposite corner
  4. Height
  5. Width
  6. Length
Method
This command has 2 methods to begin creating a box:
  • Set corner of box
  • Center
Options within the command
Set corner of box
Allows you to specify a corner for the base of the box.
Set opposite corner
Allows you to specify the opposite corner for the base of the box to apply both the length and width. The box is created parallel to the X and Y axes.
Height of box
Specifies the height of the box.
Center
Allows you to begin creating a box by specifying the center of the box.
Cube
Allows you to specify a single distance to use for the length, width, and height of the box.
Length of side
Allows you to specify the length of the side of the box.
Width of box
Specifies the width of the box.
2Point
Specifies the height of the box by picking any two points.
