DIMARC command
Creates an arc length dimension.
Icon:
Creates a dimension that measure the length of an arc or polyarc. The dimension is based
on the current dimension style. Options allow you to include a leader and specify the
angle and contents of the dimension text.
Methods to create an arc length dimension
There is one method to begin creating an arc length dimension:
- Select arc or polyline arc segment
- Begin creating an arc length dimension by selecting an arc or polyline arc segment then:
- Location of dimension arc
- Specify a point to locate the position of the dimension arc.
Options within the DIMARC command
After you begin creating an arc length dimension, the following options may be available:
- Angle
- Specify the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- Text
- Enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
- Partial
- Specify a point for the first extension line then:
- Specify second point for arc length dimension
- Specify a point for the second extension line.
- Specify the location of the dimension line.
- Leader
- Toggle on a leader from the dimension text to the arc.
- No leader
Toggle off the leader from the dimension text to the arc.
