DMCOINCIDENT3D command
Applies a coincident constraint between two subentities of 3D entities.
Icons:
Method
Applies a coincident constraint between two edges, two faces, an edge and a face or a vertex and a face or edge of two different solids or surfaces.
Options within the command
Autoconstrain
Automatically creates a coincident constraint between each pair of connected faces in selection of solids.
You can check which constraints are created in the Mechanical Browser panel or in the Parameters Manager panel.
WOrld
Allows you to select the WCS subentity as an argument.
BLock
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
