-FBXIMPORT command
Imports 3D entities from a FBX file into the current drawing via Command line.
Metoda
Specify the path of the FBX file to import via the Command line and choose the import settings.
Opcje w ramach polecenia
Ustawienia
Allows you to import or skip importing entities, lights, cameras and materials from the FBX file.
Tak
Imports the prompted element.
Nie
Skips importing the prompted element.
Wszystkie
Imports all elements from the FBX file to the current drawing.
