-FBXIMPORT command
Imports 3D entities from a FBX file into the current drawing via Command line.
Metoda
Specify the path of the FBX file to import via the Command line and choose the import settings.
Opcje w ramach polecenia
- Ustawienia
- Allows you to import or skip importing entities, lights, cameras and materials from the FBX file.
- Tak
- Imports the prompted element.
- Nie
- Skips importing the prompted element.
- Wszystkie
- Imports all elements from the FBX file to the current drawing.
