-INSERTLAYOUT command
Inserts a named layout of a drawing, as a Block Reference, in the current Paper Space.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_INTL/command-reference-lite-pro-mechanical-bim.png)
Specify the drawing path name to export the layout from and the layout name, together with the insertion point. A Block reference that replicates the entities in the layout will be inserted in the current Paper Space.
Note: The command is only available in Paper Space.
