BricsCAD Communicator
BricsCAD Communicator is an optional plug-in for Pro and higher license levels of BricsCAD that imports and exports 3D data between major CAD formats. Its high-quality conversions facilitate the re-use of 3D CAD data to improve productivity and reduce project costs.
Supported export file formats
Windows
- 3D PDF: .pdf
- ACIS: .asab, .asat, .sab, .sat
- CATIA v4: .model
- CATIA v5: .CATPart, .CATProduct
- IGES: .iges, .igs
- STEP: .step, .stp
The following export protocols can be specified; AP203, AP214, AP242
- VDA-FS:.vd
- XCGM: .xcgm
Linux
- 3D PDF: .pdf
- CATIA v4: .model
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS:.vda
Mac
- CATIA v4: .model
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS:.vda
Supported import file formats
Windows
- Autodesk Inventor: .iam, .ipt
- CATIA v4:.model
- CATIA v5/v6:.CATPart, .CATProduct, .CGR
- Creo Elements / Pro Engineer: .asm, .prt
- IGES: .iges, .igs
- NX: .prt
- Parasolid:.xmt_bin, .xmt_txt, .x_b, .x_t
- Siemens: .jt
- Solid Edge: .asm, .par, .psm
- SolidWorks: .sldasm, .sldprt
- STEP: .step, .stp, .stpz
- VDA-FS: .vda
- XCGM: .xcgm
Linux
- ACIS:.asab, .asat, .sab, .sat
- CATIA v4:.model
- IGES: .iges, .igs
- Siemens: .jt
- VDA-FS: .vda
- XCGM: .xcgm
Mac
- CATIA v4:.model
- IGES: .iges, .igs
- VDA-FS: .vda
Depending on the Communicator settings:
- You can import an assembly file, as a plain geometry (a nonhierarchical set of entities) or map its product structure into native blocks or mechanical components.
- PMI (Product and Manufacturing Information) is supported for the following file formats (Communicator license is required): ACIS, CATIA V5, NX, Pro/E / Creo, SolidWorks, XCGM. PMI annotations are imported as graphical elements grouped in blocks.
- If the assembly contains hidden parts, you can decide how to represent them in BricsCAD: 'import and hide', 'import and set visible' or just 'do not import'. This feature is currently supported on CATIA v5 only.
- You can set import options to automatically repair, stitch and simplify
imported geometry.
The IGES format has its own options to stitch and simplify. If you import a 3D model from SolidWorks, it makes sense to set an option to map Y axis into Z (because in SolidWorks the vertical axis is Y).
- For SolidWorks and other native CAD formats, it is possible to specify an alternate search path. This will be used to look for parts absent in the imported assembly folder.
