Export To GIS dialog box
Opens via: GISEXPORT command
The Export To GIS dialog box controls which GIS entities are exported and in which file format.
Format
Selects from the drop-down list the export file format for the GIS entities: ESRI SHP, GML and KML.
File name
Click the browse button () to open the Export As dialog box and indicate the file name.
Source coordinate system
Displays the coordinate system used in the current drawing.
Destination coordinate system
Selects the target coordinate system for export. Click the browse button () to open the Choose GIS Coordinate System dialog box.
Entities
Selects the entities to export.
Select GIS layer
Selects the GIS layers to export.
Click the browse button () to open the Select GIS layers dialog box.
Select entities in drawing
Selects the entities in the drawing.
Geometry type
Chooses the geometry type from the drop-down list.
Note: The ESRI SHP export file format does not support layers with different geometry types.
Attribute data
Selects the GIS attributes to be included in the export.
Manage attributes... button
Opens the Manage attributes dialog box.
Attributes list
Lists the attributes selected for export.
Field name
Displays the field name.
Field type
Displays the field type.
Export name
Displays the export name. Click the Export name field to edit the default name of the attribute.
Delete
Click the trash button () to remove the selected attribute.
Note: An empty state component displays when the selected entities in the drawing do not contain any GIS attribute data.
Options
Sets the GIS export options.
Specify export area
Defines the export area from the drop-down list.
Export all
Uses the entire drawing as export area.
Select clipping polygon
Click the mouse icon to select a polygon in the drawing that defines the export area.
Draw clipping polygon
Click the mouse icon to draw a polygon that defines the export area.
Override KML altitude
Selects how the altitude of the entity is interpreted as terrain elevation in Google Earth when exporting to KML.
Clamp to ground
Ignores the altitude of the entity specification and only uses the terrain elevation at the location.
Relative to ground
Interprets the altitude of the entity as relative to the terrain elevation at the location, adding the altitude value to the terrain elevation.
Absolute
Interprets the altitude of the entity as relative to sea level, using this value for terrain elevation.
Enable export of entities without GIS data
Sets to export the entities without GIS data.
