Select Alignment dialog box
Opens via:
- ALIGNMENTVERTICALMANAGE command
- ALIGNMENTVIEW command
The Select Alignment dialog box allows you to select a horizontal alignment.
- Select in drawing
- Allows you to select a horizontal alignment in the drawing.
- List of alignments
- Allows you to select an available horizontal alignment from the list.
