BDEPENDENCYHIGHLIGHT system variable
Highlight dependent objects
Highlights all objects that are dependent on a selected action or parameter in the Block Editor.
| Wpisz: |
Boolowskie |
| Zapisano w: |
Rejestr |
| Domyślna wartość: |
Na |
| Możliwe wartości: |
Off (0): Dependent objects are not highlighted when an action or parameter is selected. On (1): Dependent objects are highlighted when an action or parameter is selected. |
