CMDSUGGESTIONSORTING system variable
Sorting of Command Suggestions
Controls the algorithm used to rank suggestions in the command line autocomplete.
| Wpisz: |
Krótki |
| Zapisano w: |
Rejestr |
| Domyślna wartość: |
1 |
| Możliwe opcje: |
0: Alphabetically 1: According to global command usage |
Note: Command suggestions, sorted according to global command usage, are ranked by usage, with exact matches appearing first. Commands with the same ranking are sorted alphabetically, while LISP commands, settings and custom or third-party commands are given lower priority.
