COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import/export is performed.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: |
On |
Possible values: |
Off (0): Disable the import and export in background On (1): Enable the import and export in background |
