DELETEINTERFERENCE system variable
Delete interference
Controls the behavior of the INTERFERE command.
If on, the first set of solids are subtracted from the second set.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t solve interferences after commands
On (1): Solve interferences after commands
