DIMMARKTYPE system variable
Dimension override marking
Automatically displays overridden associative dimensions with a special marking, when they do not include the default dimension text.
BricsCAD only
Type:
Short
Saved in:
Drawing
Range:
0 to 2
Default value:
0
Possible values:
0: Not enabled
1: Display overridden dimensions with an underline
2: Display overridden dimensions with an overline
