DIMSOXD system variable
Dim line inside
Suppresses arrowheads outside extension lines if there is insufficient room inside the extension lines and if the DIMTIX system variable is on (1).
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t suppress outside arrowheads On (1): Suppress outside arrowheads |
