DIMTIX system variable
Text inside
Draws dimension text between extension lines, even if there is insufficient room.
Note: It does not apply to radius and diameter dimensions.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t force text between extension lines On (1): Force text between extension lines |
