DRAWINGVIEWBGENPAR system variable
Parallel generation of drawing views
Enables parallel generation of drawing views during the VIEWBASE command.
Only effective when background generation is enabled.
Tylko BricsCAD
Wpisz:
Boolowskie
Zapisano w:
Rejestr
Domyślna wartość:
WYł
Możliwe wartości:
Off (0): Disable parallel generation of drawing views
On (1): Enable parallel generation of drawing views
