DRAWINGVIEWBGENPAR system variable
Parallel generation of drawing views
Enables parallel generation of drawing views during the VIEWBASE command.
Only effective when background generation is enabled.
Tylko BricsCAD
| Wpisz: |
Boolowskie |
| Zapisano w: |
Rejestr |
| Domyślna wartość: |
WYł |
| Możliwe wartości: |
Off (0): Disable parallel generation of drawing views On (1): Enable parallel generation of drawing views |
