HLRNEXTGEN system variable
Next generation hidden line removal
Speed up parallel hidden line removal by using an experimental next generation algorithm.
Tylko BricsCAD
| Wpisz: |
Boolowskie |
| Zapisano w: |
Rejestr |
| Domyślna wartość: |
WYł |
| Możliwe wartości: |
Off (0): Don’t use next generation algorithm to speed up hidden line removal On (1): Use next generation algorithm to speed up hidden line removal (Experimental) |
