REGENMODE system variable
Regeneration mode
Toggles the automatic regeneration of the drawing On/Off. BricsCAD will regenerate the display automatically when REGENMODE is On, but in a few cases a forced regeneration of the drawing might be necessary. This is done by the REGEN command.
| Type: | Boolean  |
| Saved in: | Drawing  |
| Default value: | On  |
| Possible values: |
                            Off (0): Turn off REGENAUTO command On (1): Turn on REGENAUTO command  |
