account
translation
Bricsys Help Center
RULERDISPLAY system variable
Ruler Display
Specifies the display of the ruler when moving objects using the manipulator or the DMPUSHPULL command.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Do not display ruler
On (1): Display ruler when objects are moved using the manipulator or the DMPUSHPULL command.
Parent topic: Odniesienie do zmiennej systemowej
Related variables
  • MANIPULATOR zmienna systemowa
  • RULERTEXTCOLOR system variable
Related information
  • The manipulator
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
