SELECTSIMILARMODE system variable
Match options for SELECTSIMILAR
Controls which properties must match for the SELECTSIMILAR command. For this command to operate as intended, at least one property must be turned on. When all properties are turned off, this command selects only the entity(ies) you pick at the Select entities prompt.
Wpisz: | Krótki |
Zapisano w: | Rejestr |
Zakres: |
0 to 255 |
Domyślna wartość: |
130 |
Możliwe opcje: |
0: Entity type 1: Color 2: Layer 4: Linetype 8: Linetype scale 16: Lineweight 32: Plot style 64: Entity style 128: Name |
