SMCONVERTBENDCOAXIALTOLERANCEFACTOR system variable
Tolerance factor on bend geometry
Tolerance on geometry of a bend, relative to the outer radius.
Lower values reduce (false) bend recognition, default 2.0, recommended 0.25.
Values between 0.01 and 10.0 are accepted.
Tylko BricsCAD
| Wpisz: |
Rzeczywista |
| Zapisano w: |
Rysunek |
| Zakres: |
0.01 to 10 |
| Domyślna wartość: |
2 |
