STRUCTURETREECONFIG system variable
Structure Tree Configuration
Name of the active Structure Tree configuration file. Use the SRCHPATH command to find the file.
Loading a different CST file than the default file changes the way that the STRUCTUREPANEL command presents drawing data.
BricsCAD only
Type: | String |
Saved in: | Workspace |
Default value: |
default.cst |
