SALVAR comando [SAVE]
Abre a caixa de diálogo Salvar Desenho Como.
Ícone:
Alias: SA
Descrição
Abre a caixa de diálogo Salvar Desenho Como para salvar dados do atual desenho para um arquivo DWG, DXF, DWT, ou DWS.
Os tipos de arquivo disponíveis para salvar são:
- AutoCAD 2018 (*dwg)
- AutoCAD 2018 ASCII DXF (*dxf)
- AutoCAD 2018 Binary DXF (*dxf)
- AutoCAD 2013 (*dwg)
- AutoCAD 2013 ASCII DXF (*dxf)
- AutoCAD 2013 Binary DXF (*dxf)
- AutoCAD 2010 (*dwg)
- AutoCAD 2010 ASCII DXF (*dxf)
- AutoCAD 2010 Binary DXF (*dxf)
- AutoCAD 2007 (*dwg)
- AutoCAD 2007 ASCII DXF (*dxf)
- AutoCAD 2007 Binary DXF (*dxf)
- AutoCAD 2004 (*dwg)
- AutoCAD 2004 ASCII DXF (*dxf)
- AutoCAD 2004 Binary DXF (*dxf)
- AutoCAD 2000 (*dwg)
- AutoCAD 2000 ASCII DXF (*dxf)
- AutoCAD 2000 Binary DXF (*dxf)
- AutoCAD Release 14 (*dwg)
- AutoCAD Release 14 ASCII DXF (*dxf)
- AutoCAD Release 14 Binary DXF (*dxf)
- AutoCAD Release 13 Drawing (*dwg)
- AutoCAD Release 13 ASCII DXF (*dxf)
- AutoCAD Release 13 Binary DXF (*dxf)
- AutoCAD Release 11/12 Drawing (*dwg)
- AutoCAD Release 11/12 ASCII DXF (*dxf)
- AutoCAD Release 11/12 Binary DXF (*dxf)
- AutoCAD Release 10 ASCII DXF (*dxf)
- AutoCAD Release 10 Binary DXF (*dxf)
- AutoCAD Release 9 ASCII DXF (*dxf)
- Standards File (*dws)
- Drawing Template (*dwt)
