Создание и разделение лофт-гибов
BricsCAD позволяет создавать или распознавать детали из листового металла с криволинейной геометрией, которые могут быть изготовлены с использованием нескольких операций гиба.
Создание детали из листового металла с лофт-гибами
- Launch the SMLOFT command.
- Выполните одно из следующих действий:
- Click the Create Lofted Bend tool button () on the Sheet Metal toolbar.
- Click the Create Lofted Bend tool button () on the Sheet Metal ribbon bar.
- Choose Create Sheet Metal Loft in the
Sheet Metal menu.You are prompted: Select two cross sections:
- Select 2 profile entities.You are prompted: Set fillets Radius/Thickness/Single bend/<Flanges with bends>:
- Press Enter to accept the default settings.A preview of the sheet metal part is created.You are prompted: Set fillets Radius/Thickness/Single bend/Flanges with bends or make thicken Both sides/Inside/<Outside>:
- Press the CTRL key to choose the position of the sheet metal part thickness with respect to the source profiles:
Left, Center or
Right.If the HKA field in the Status Bar is ON, the Hotkey Assistant widget displays.
- Press Enter to create the sheet metal part.If FEATURECOLORS is ON, you can distinguish between the 2 flanges () and the lofted bend ().
The properties of the lofted bend display in the Mechanical Browser:
При необходимости, вы можете выбрать лофт-гиб и изменить его свойства:
- Number of subdivisions: the number of flat regions in the unfolded representation of a lofted bend feature (the greater the number, the more bend lines will be added to the unfolded view for the lofted bend).
- Force triangulation: most of lofted bends can be unfolded using an intelligent algorithm of quad tessellation. However, sometimes it might produce non-optimal results. In such cases set this property to Да to switch to a more straight-forward algorithm, which creates triangle-like quads.
Разделение лофт-гиба
Лофт-гибы могут быть разделены вдоль линии, проходящей по лофт-поверхности через произвольную точку:
- Click the Split tool () on the Sheet Metal ribbon tab.
- Choose Split the Sheet Metal menu.
- Type smsplit in the Command line.You are prompted: Select flange or lofted bend face:
- Select a lofted bend face.You are prompted: Select point on lofted bend face:
- Укажите точку на поверхности лофт-гиба.
Лофт-гиб будет разделен. При необходимости, вы можете свободно отделить и переместить полученную после разделения часть гиба.
