Civil commands
The Civil commands are listed in the table below:
Name | Title | Description |
Open the Civil Explorer panel. | Opens the Civil Explorer panel to display it in the current workspace. | |
Close the Civil Explorer panel. | Closes the Civil Explorer panel to hide it from the current workspace. | |
TIN Surface |
Creates a topographical (TIN) surface. |
Edit TIN Surface |
Adds or removes points, breaklines or boundaries on a TIN surface. |
Modify TIN Surface |
Deforms or smooths a TIN surface. |
TINMERGE command |
Merge TIN Surfaces |
Combines two or more TIN surfaces into a single TIN surface. |
TINASSIGNIMAGE command |
Assign Image to TIN Surface |
Assigns a raster image to a TIN surface, as a material. |
TINPROJECT команда |
Project to TIN Surface |
Projects points (points, blocks and text) or linear entities (lines, polylines and circles) to a TIN surface. |
TINEXTRACT command |
Extract from TIN Surface |
Extracts meshes, solids, points, faces, contours or borders from a TIN surface. |
TINWATERDROP команда |
Water Drop |
Creates a water drop path on a TIN Surface. |
GRADING command |
Grading |
Creates a graded surface on a TIN surface. |
GRADINGEDIT command |
Grading Edit |
Splits or merges gradings. |
GRADINGBALANCE команда |
Balance Grading Volumes |
Balances grading cut and fill volumes. |
TINVOLUME command |
TIN Volume Surface |
Creates a TIN volume surface between a base and comparison TIN surface, or an elevation. |
ADDSURFACELABELS команда |
Add Surface Labels |
Adds spot elevation labels, slope labels or contour labels on a surface. |
CIVILPOINT команда |
Civil Points |
Creates civil points (civil entities) represented by symbols and labels. |
CIVILPOINTGROUP команда |
Civil Points Groups |
Creates civil point groups. |
CIVILPOINTATTRIBUTES команда |
Civil Point Attributes |
Adds or removes user-defined attributes, to civil points. |
ALIGNMENT command |
Alignment by PI |
Creates horizontal, vertical and 3D alignments. |
ALIGNMENTLINE command |
Alignment by Element - Line |
Creates an unconstrained, horizontal, line alignment. |
ALIGNMENTCURVE command |
Alignment by Element - Curve |
Creates an unconstrained, horizontal, curve alignment. |
ALIGNMENTELEMENTFROM command | Alignment by Element - To/From Element |
Creates a horizontal alignment, constrained on one side by another element. |
ALIGNMENTELEMENTBETWEEN command |
Alignment by Element - Between Elements |
Creates a horizontal alignment constrained on both sides by other elements. |
ALIGNMENTEDIT command |
Edit Alignment |
Edits a horizontal or vertical alignment. |
ALIGNMENTVIEW command |
Vertical Alignment View |
Creates a vertical alignment view for a horizontal or 3D alignment. |
ALIGNMENTVERTICAL command |
Vertical Alignment |
Creates a vertical alignment. |
ALIGNMENT3D команда |
3D Alignment |
Creates a 3D alignment from horizontal and vertical alignments. |
CORRIDOR команда |
Corridor |
Creates a corridor from a corridor template. |
CORRIDOREDIT command |
Edit Corridor |
Adds or removes a corridor region. |
CORRIDOREXTRACT команда |
Extract from Corridor |
Extracts 3D solids, meshes, TIN surfaces, 3D polylines or outer boundaries, from a corridor. |
CORRIDORTEMPLATE команда |
Corridor Template |
Creates a corridor template. |
CORRIDORTEMPLATEELEMENT команда |
Corridor Template Element |
Creates a corridor template element from closed polylines. |
CORRIDORTEMPLATEELEMENTEDIT команда |
Edit Corridor Template Element |
Adds or removes components to corridor template elements. |
CIVIL3DIMPORT команда |
Import Civil 3D |
Imports objects from a Civil 3D drawing. |
LANDXMLIMPORT command |
Import LandXML |
Creates TIN surfaces or alignments from a LandXML file. |
GISIMPORT command |
GIS Import |
Imports spatial and attribute data from an ESRI SHP file. |
IFCEXPORT command |
Export to IFC |
Exports the model to an IFC file. |
LANDXMLEXPORT команда |
Export LandXML |
Exports Civil entities to a LandXML file. |
GISEXPORT команда |
GIS Export |
Exports spatial and attribute data in an ESRI SHP file. |
CIVILDWGEXPORT команда |
Export DWG |
Exports civil objects as native DWG entities. |
MAPTRIM command |
Boundary Trim |
Trims objects to a boundary: closed polylines, circles, closed splines or ellipses. |
