Add Property dialog box
The Add Property dialog box allows you to add properties to text contents for label styles.
  1. Use property from other objects
  2. Object type
  3. Object name
  4. Select property
Toggle this option if you want to add properties from other Civil objects to this Label Style.
Object type
Select the object type from which you want to select the property. Properties can be added from Civil Points, Surfaces, Horizontal Alignments, or Vertical Alignments.
Object name
Displays the object name.
Select property
Select the property you wish to include in the Label Style. It is possible to include the following attributes:
From Civil Point:
  • Name
  • Description
  • Point Easting
  • Point Northing
  • Point Elevation
  • Point Fill Description
  • Point Number
  • *User-defined attribute for Civil Point*
From Surface:
  • Name
  • Description
  • Surface Elevation
  • Surface Northing
  • Surface Easting
  • Surface Grid Northing
  • Surface Grid Easting
  • Surface Latitude
  • Surface Longitude
  • Surface Slope
  • Surface Slope Distance
  • Surface Slope Horizontal Distance
  • Surface Slope Depts
  • Surface Elevation First Point
  • Surface Elevation Seconds Point
From Horizontal Alignment:
  • Name
  • Description
  • Alignment Station Value
  • Alignment Offset Value
From Vertical Alignment:
  • Name
  • Description
  • Vertical Alignment Station Value
Note: When adding properties from Surface, Vertical or Horizontal Alignment to be shown in the Label Style, make sure to select the appropriate references in the properties panel of Civil Points.
