GCFIX command
Creates a fixed geometric constraint on 2D entities.
Icon:
Description (Описание)
Creates a fixed constraint on a point or entity to maintain its position in the drawing.
Methods to create a fixed constraint
This command has 2 methods to create a fixed constraint:
- Select point
- Объект
- Select point
- Create a fixed constraint by specifying a point on an entity. The point maintains its position while other geometry moves, as necessary, to maintain other constraints.
- Объект
- Create a fixed constraint by selecting an entity. The entity maintains its position while other geometry moves, as necessary, to maintain other constraints.
