GEOGRAPHICLOCATION command
Opens the Geographic Location dialog box.
Icon:
Alias: GEO
About CSMAP
CSMAP is a coordinate system and map projection that allows users to access more geographic coordinates conversions and more precise geospatial analysis. Coordinate systems are a very important piece of mapping or geospatial coordinates, and are constantly updated.
You can download and install CSMAP coordinate system on demand:
- Click here to download the CSMAP coordinate system.
- Unzip the archive and copy the content of the coordinate_system folder in the BricsCAD installation folder.
The default path is: C:\Program Files\Bricsys\BricsCAD en_US.
- The next time BricsCAD is started, the GEOGRAPHICLOCATION command will display a combined list of coordinate systems form Geodatabase.xml and CoordinateSystemFiles folder.
