OOPS command Restores the last erased entity. Icon: Alias: UNDELETE, UNERASE Description Restores the last erased entity, including those erased by the Block command. If there are no erased entities in the drawing, BricsCAD indicates: There is nothing to un-erase. This command displays no prompts and has no options. Parent topic: Справочник командRelated commandsERASE commandREDO командаU командаUNDO команда
