QRTEXT command
Creates an MText and displays it as a QR code.
Icon:
Creates an MText which is represented as QR code by default.
Note:
- The QR code for a text is represented as a raster image.
- You can use the Properties panel to switch every
text or mtext to QR code by setting the Enabled
option to Yes (1), editing the Optical
image size (2) and controlling the type of QR code by
changing the Optical hint option (3).
The Optical hint option allows you to specify 7 types of hints for QR code scanner: EMail, Phone, vCard, MeCard, Sms, Mms, Geolocation.
Options within the command
The Command line options are identical to the Command line options in the MTEXT command. See the MTEXT command article for details.
