_QUADTABFLAGS system variable
Quad tab flags
Temporary setting used while new Quad tab layout is implemented.
The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 31
Default value:
12
Possible options:
1: Fixed width tabs
2: Center tab labels
4: Tab borders
8: Double tab height
16: Show 3D Solid mass properties
