ACADLSPASDOC system variable
on_start.lsp for each doc
Loads the on_start_default.lsp, on_start.lsp, on_doc_load.lsp and on_doc_load_default.lsp files, for every new drawing.
If off, only loads these files for the first drawing.
Type: |
Boolean |
Saved in: |
Registry |
Default value: |
Off |
Possible values: |
Off (0): Do not load on_start.lsp with every drawing On (1): Load on_start.lsp with every drawing |
