ARCTESSELLATION system variable
Arc approximation mid-ordinate distance
Controls the surface mid-ordinate distance, the maximum distance between the arc and the chord (straight) segment, used for arc approximation.
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Default value: | 0.01 |
