AUDITCTL system variable
Audit control
Creates an audit report (ADT) file when the AUDIT command is used.
When you turn on the AUDITCTL settings variable, AUDIT creates an ASCII file describing problems and the action taken. This report, with the file extension ADT, is placed in the same directory as the current drawing.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Don’t write ADT files
On (1): Write ADT files
