BIMDEFAULTPROPERTIESPATH system variable
Default properties path
The file paths for properties, loaded when a new document is opened.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
Default value: | bimproj_user.xml;bimproj_IFC2x3.xml;bimproj_IFC4.xml;bimproj_quantity.xml |
