BLOCKSPATH system variable
Blocks path
Specifies the file path used for the fifth folder on the left side of the Select Drawing File dialog box, opened with the INSERT command when the Browse option is selected.
BricsCAD only
Type: |
String Standard |
Saved in: | Preference |
