CMDLINEFADINGLOGTRANSPARENCY system variable
Command line fade log transparency
Controls the Command line fade log transparency.
Values between 0 and 100 are accepted. A value of zero means fully opaque, 100 is fully transparent.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 100
Default value:
30
