CMDLINEFRAMEACTIVETRANSPARENCY system variable
Command line frame transparency when active
Controls Command line frame transparency when active. Values between 0 and 100 are accepted.
A value of zero means fully opaque, 100 if fully transparent.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 100
Default value:
10
