CMDLINEUSEMINIFRAME system variable
Command line mini floating frame
Controls if the mini-frame is used when the Command line floats.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t use new mini-frame
On (1): Use new mini-frame
Note: The CMDLINEUSEMINIFRAME system variable replaces the CMDLINEUSENEWFRAME system variable.
