DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
Import active model to Model Space
Specifies how active spaces are handled. If on, BricsCAD imports the active dgn model to dwg Model Space. Otherwise BricsCAD imports the first dgn design model from the model table to the dwg Model Space. Microstation uses the phrase “design model” for model space, and “active model” for the current view of a model.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Import the first design model from the model table to the model space On (1): Import the active model to model space |
