DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
Import active model to Model Space
Imports the active DGN model to Model Space, during DGN import. If off, imports only the first DGN design model from the model table.
Note: Microstation uses the phrase “design model” for model space, and “active model” for the current view of a model.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Import the first design model from the model table to the model space
On (1): Import the active model to model space
