DGNIMPIMPORTPAPERSPACEMODELS system variable
Import Paper Space models
Imports all DGN sheet models to paper space layouts. If off, sheet models are not imported.
Note: Microstation uses the phrase “sheet model” for paper space.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t import sheet models
On (1): Import sheet models to paper space layouts
