DIMSD1 system variable
Dim line 1
Suppresses the first part of dimension lines - from the first extension line to the text origin.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t suppress first dimension line On (1): Suppress first dimension line |
