DIMTFAC system variable
Tolerance text height
Controls the scale multiplier used to calculate the text height for dimension fractions and tolerances, relative to the dimension text height, set with the DIMTXT system variable. Only applies if the DIMLUNIT system variable is set to Fractional (5).
Type: | Real |
Saved in: | Drawing |
Default value: | 1.0 |
