DRAWINGVIEWASM system variable
Assemblies optimization
Enables the use of assembly data structures, optimizes the generation of views created with the VIEWBASE command.
Toggles between normal analytical hidden line removal (HLR) and ASM_HLR procedure.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disable assemblies optimization
On (1): Enable assemblies optimization
